Aller au contenu principal
HP 15-da0012dx SSD Replacement
Ce dont vous avez besoin
  1. HP 15-da0012dx SSD Replacement, Battery: étape 1, image 1 de 2 HP 15-da0012dx SSD Replacement, Battery: étape 1, image 2 de 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: étape 2, image 1 de 3 HP 15-da0012dx SSD Replacement: étape 2, image 2 de 3 HP 15-da0012dx SSD Replacement: étape 2, image 3 de 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: étape 3, image 1 de 2 HP 15-da0012dx SSD Replacement: étape 3, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: étape 4, image 1 de 2 HP 15-da0012dx SSD Replacement: étape 4, image 2 de 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx SSD Replacement: étape 5, image 1 de 3 HP 15-da0012dx SSD Replacement: étape 5, image 2 de 3 HP 15-da0012dx SSD Replacement: étape 5, image 3 de 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: étape 6, image 1 de 2 HP 15-da0012dx SSD Replacement: étape 6, image 2 de 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: étape 7, image 1 de 2 HP 15-da0012dx SSD Replacement: étape 7, image 2 de 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx SSD Replacement, SSD: étape 8, image 1 de 2 HP 15-da0012dx SSD Replacement, SSD: étape 8, image 2 de 2
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: étape 9, image 1 de 2 HP 15-da0012dx SSD Replacement: étape 9, image 2 de 2
    • Pull the SSD module away from the socket.
5 autres ont terminé cette réparation.
Xavier Hung
Membre depuis le 02/07/19
914 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team S20-G4, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
3 membres
7 tutoriels rédigés
Un commentaire
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 94
Total : 8,863
