Introduction
If your laptop screen is broken or damaged, use this guide to replace the screen. To do so you need a Phillips #1 screwdriver, opening tools, tweezers, and safe pry tools. There are some difficult steps to this guide, especially be careful not to damage any wires in this process.
Ce dont vous avez besoin
Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
Flip the computer over and open the screen.
Start from a corner and run the plastic opening tools along the edge of the back cover.
After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
Gently pry back the cover starting from the middle, bottom edge.
Remove the 3 mm Phillips #0 screw securing the WLAN card in place.
Carefully remove the WLAN card from the motherboard.
Gently remove the antenna cable from the wire guides in the speaker and chassis.
Place WLAN card off to the side being careful not to pull on the antenna cable.
2 autres ont terminé cette réparation.
