Aller au contenu principal
HP 15-db0004dx Fan Replacement
Ce dont vous avez besoin
  1. HP 15-db0004dx Fan Replacement, Bottom Case: étape 1, image 1 de 2 HP 15-db0004dx Fan Replacement, Bottom Case: étape 1, image 2 de 2
    • Turn the laptop off and unplug it before starting.
    • Flip your laptop over, face down.
  2. HP 15-db0004dx Fan Replacement: étape 2, image 1 de 1
    • Peel off the two long rubber grips running lengthwise on the laptop.
  3. HP 15-db0004dx Fan Replacement: étape 3, image 1 de 2 HP 15-db0004dx Fan Replacement: étape 3, image 2 de 2
    • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
  4. HP 15-db0004dx Fan Replacement: étape 4, image 1 de 1
    • Carefully slide the optical drive out of the laptop.
  5. HP 15-db0004dx Fan Replacement: étape 5, image 1 de 1
    • Use a plastic opening tool to separate the back panel from the laptop.
    • For an easier removal, start at the corner and run the tool along the edge of the cover.
    • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
    • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
  6. HP 15-db0004dx Fan Replacement, Fan: étape 6, image 1 de 3 HP 15-db0004dx Fan Replacement, Fan: étape 6, image 2 de 3 HP 15-db0004dx Fan Replacement, Fan: étape 6, image 3 de 3
    • Using a Phillips #000 screwdriver remove the 5mm screw holding the fan in place.
  7. HP 15-db0004dx Fan Replacement: étape 7, image 1 de 3 HP 15-db0004dx Fan Replacement: étape 7, image 2 de 3 HP 15-db0004dx Fan Replacement: étape 7, image 3 de 3
    • After the screw is removed, carefully unplug the set of wires with one of each colored, red, black, yellow, and blue, from the white connector it is secured at.
    • To unplug it gently pull the white connector from the adapter, possibly in a back and forth motion to free it.
    • DO NOT pull on the wires, doing so could cause damage to the wires, or for them to become disconnected to the white adapter they are attached to.
  8. HP 15-db0004dx Fan Replacement: étape 8, image 1 de 3 HP 15-db0004dx Fan Replacement: étape 8, image 2 de 3 HP 15-db0004dx Fan Replacement: étape 8, image 3 de 3
    • Carefully remove the fan from the laptop.
    • Be careful with removal as to not bend or break anything. There is a metal peg shown in the image, that the fan is secured on that could potentially bend
Britanni Arizola
Membre depuis le 09/22/22
562 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 13
Total : 113
