Introduction
If you ever need to replace your motherboard due to water damage, electricity damage broken parts, etc, or simply you just want to upgrade your motherboard, follow this guide to remove it.
Ce dont vous avez besoin
Using a Phillips #000 screwdriver remove the 5mm screw holding the fan in place.
Gently pull apart the two silver arms securing the RAM until it slightly flips up.
Pull the RAM directly out of its port.
