Introduction
Use this guide if the SD card reader or the USB drive located on the right side of the HP 15-db0015dx laptop stops working. Before starting this guide be sure to eject the SD card inside the laptop if applicable, remove any USB connectors and fully power off the device.
Ce dont vous avez besoin
Power off the device before starting.
Remove the rubber strips that hide the screws using the spudger.
Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
Pull the hard drive bracket out.
Lift up on the connector pin that attaches the SD card reader to the motherboard
Gently pull the wire out
