Aller au contenu principal
HP 15-db0015dx WLAN Module Replacement
Ce dont vous avez besoin
  1. HP 15-db0015dx WLAN Module Replacement, Battery: étape 1, image 1 de 2 HP 15-db0015dx WLAN Module Replacement, Battery: étape 1, image 2 de 2
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
  2. HP 15-db0015dx WLAN Module Replacement: étape 2, image 1 de 3 HP 15-db0015dx WLAN Module Replacement: étape 2, image 2 de 3 HP 15-db0015dx WLAN Module Replacement: étape 2, image 3 de 3
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
  3. HP 15-db0015dx WLAN Module Replacement: étape 3, image 1 de 3 HP 15-db0015dx WLAN Module Replacement: étape 3, image 2 de 3 HP 15-db0015dx WLAN Module Replacement: étape 3, image 3 de 3
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
  4. HP 15-db0015dx WLAN Module Replacement, WLAN Module: étape 4, image 1 de 1
    • Disconnect the wire attached to the WLAN card by prying it upward from the card.
  5. HP 15-db0015dx WLAN Module Replacement: étape 5, image 1 de 1
    • Remove the screw holding down the card with a Phillips #0 screwdriver.
  6. HP 15-db0015dx WLAN Module Replacement: étape 6, image 1 de 2 HP 15-db0015dx WLAN Module Replacement: étape 6, image 2 de 2
    • Pull the WLAN Module out of the connection port.
Daniel McGuire
Membre depuis le 01/29/20
193 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 467
