Aller au contenu principal
HP 15-dw Back Cover Replacement
Ce dont vous avez besoin
  1. HP 15-dw Back Cover Replacement, Prepare your laptop for disassembly: étape 1, image 1 de 1
    • Fully shut down your laptop and unplug all cables.
  2. HP 15-dw Back Cover Replacement, Flip your laptop over: étape 2, image 1 de 1
    • Flip your laptop over so the rubber feet are facing up.
  3. HP 15-dw Back Cover Replacement, Peel up an end of the front foot: étape 3, image 1 de 3 HP 15-dw Back Cover Replacement, Peel up an end of the front foot: étape 3, image 2 de 3 HP 15-dw Back Cover Replacement, Peel up an end of the front foot: étape 3, image 3 de 3
    • The rubber feet cover a total of five back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  4. HP 15-dw Back Cover Replacement, Remove the front foot: étape 4, image 1 de 3 HP 15-dw Back Cover Replacement, Remove the front foot: étape 4, image 2 de 3 HP 15-dw Back Cover Replacement, Remove the front foot: étape 4, image 3 de 3
    • Peel the front foot away from the back cover and remove it.
  5. HP 15-dw Back Cover Replacement, Remove the rear foot: étape 5, image 1 de 3 HP 15-dw Back Cover Replacement, Remove the rear foot: étape 5, image 2 de 3 HP 15-dw Back Cover Replacement, Remove the rear foot: étape 5, image 3 de 3
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  6. HP 15-dw Back Cover Replacement, Reassembly information: étape 6, image 1 de 3 HP 15-dw Back Cover Replacement, Reassembly information: étape 6, image 2 de 3 HP 15-dw Back Cover Replacement, Reassembly information: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Tesa 61395 Tape
    $5.99
    • Note that the rubber feet are different:
    • The front foot is thicker, with a deeper recess.
    • The rear foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
  7. HP 15-dw Back Cover Replacement, Unfasten the back cover: étape 7, image 1 de 2 HP 15-dw Back Cover Replacement, Unfasten the back cover: étape 7, image 2 de 2
    • Use a Phillips screwdriver to remove the seven screws securing the back cover:
    • Five 8.5 mm-long screws
    • Two 4.6 mm-long screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  8. HP 15-dw Back Cover Replacement, Open your laptop: étape 8, image 1 de 3 HP 15-dw Back Cover Replacement, Open your laptop: étape 8, image 2 de 3 HP 15-dw Back Cover Replacement, Open your laptop: étape 8, image 3 de 3
    • Flip your laptop over and open the screen.
  9. HP 15-dw Back Cover Replacement, Release the clips: étape 9, image 1 de 2 HP 15-dw Back Cover Replacement, Release the clips: étape 9, image 2 de 2
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
    • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
  10. HP 15-dw Back Cover Replacement: étape 10, image 1 de 2 HP 15-dw Back Cover Replacement: étape 10, image 2 de 2
    • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
    • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
  11. HP 15-dw Back Cover Replacement: étape 11, image 1 de 3 HP 15-dw Back Cover Replacement: étape 11, image 2 de 3 HP 15-dw Back Cover Replacement: étape 11, image 3 de 3
    • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
    • Slide the opening pick to the bottom left corner to release the remaining clips.
  12. HP 15-dw Back Cover Replacement, Flip your laptop over: étape 12, image 1 de 3 HP 15-dw Back Cover Replacement, Flip your laptop over: étape 12, image 2 de 3 HP 15-dw Back Cover Replacement, Flip your laptop over: étape 12, image 3 de 3
    • Close the screen and flip your laptop back over.
  13. HP 15-dw Back Cover Replacement, Remove the back cover: étape 13, image 1 de 3 HP 15-dw Back Cover Replacement, Remove the back cover: étape 13, image 2 de 3 HP 15-dw Back Cover Replacement, Remove the back cover: étape 13, image 3 de 3
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
Spencer Day
Membre depuis le 09/14/22
95 787 Réputation
662 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 581 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 44
30 derniers jours : 175
Total : 3,013
