Aller au contenu principal
HP 15-dw2065st Fan Replacement
Ce dont vous avez besoin
  1. HP 15-dw2065st Fan Replacement, Fan: étape 1, image 1 de 2 HP 15-dw2065st Fan Replacement, Fan: étape 1, image 2 de 2
    • Press the top left button to turn the laptop off.
    • Make sure the laptop is unplugged.
    • The light on the left side of the base of the laptop indicates if the laptop is on or off.
  2. HP 15-dw2065st Fan Replacement: étape 2, image 1 de 3 HP 15-dw2065st Fan Replacement: étape 2, image 2 de 3 HP 15-dw2065st Fan Replacement: étape 2, image 3 de 3
    • Close the screen and flip the laptop over so the backside is facing up.
    • Using a Phillips screwdriver, remove the left and right corner screws.
  3. HP 15-dw2065st Fan Replacement: étape 3, image 1 de 3 HP 15-dw2065st Fan Replacement: étape 3, image 2 de 3 HP 15-dw2065st Fan Replacement: étape 3, image 3 de 3
    • Use a spudger or your fingers to remove the protective padding from the top and bottom of the base and expose the screws.
    • With a Phillips screwdriver, remove the five screws from the base.
  4. HP 15-dw2065st Fan Replacement: étape 4, image 1 de 3 HP 15-dw2065st Fan Replacement: étape 4, image 2 de 3 HP 15-dw2065st Fan Replacement: étape 4, image 3 de 3
    • Open the screen.
    • Use a spudger to pry the palm rest assembly from the laptop.
    • Work the spudger around the perimeter to release the clips that secure the palm rest assembly.
    • Remove the palm rest assembly carefully as there are ribbon cables attached on the other side.
  5. HP 15-dw2065st Fan Replacement: étape 5, image 1 de 2 HP 15-dw2065st Fan Replacement: étape 5, image 2 de 2
    • With a Phillips screwdriver, remove the four screws securing the battery.
    • Remove the battery from the connector.
  6. HP 15-dw2065st Fan Replacement: étape 6, image 1 de 1
    • Use a spudger to lift the black locking flap.
    • Remove the ribbon cable.
  7. HP 15-dw2065st Fan Replacement: étape 7, image 1 de 3 HP 15-dw2065st Fan Replacement: étape 7, image 2 de 3 HP 15-dw2065st Fan Replacement: étape 7, image 3 de 3
    • Remove the black screw from the fan.
    • Pull the cable away from the connector in the same direction that the individual wires are running
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the fan.
  8. HP 15-dw2065st Fan Replacement: étape 8, image 1 de 2 HP 15-dw2065st Fan Replacement: étape 8, image 2 de 2
    • Set the new fan in place.
    • Plug in the new fan.
    • Screw in the new fan.
    • Return all parts to the base.
    • Close the base.
Ligne d'arrivée
Jonathan Bentley
Membre depuis le 05/24/23
157 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 13
Total : 168
