Aller au contenu principal
HP 15-dy2024nr Display Assembly Replacement
Ce dont vous avez besoin
  1. HP 15-dy2024nr Display Assembly Replacement, Display Assembly: étape 1, image 1 de 2 HP 15-dy2024nr Display Assembly Replacement, Display Assembly: étape 1, image 2 de 2
    • Peel the inner edge of the bezel using an opening tool and gently snap both edges away from the glass.
    • Go around the perimeter and begin snapping the tabs underneath.
  2. HP 15-dy2024nr Display Assembly Replacement: étape 2, image 1 de 3 HP 15-dy2024nr Display Assembly Replacement: étape 2, image 2 de 3 HP 15-dy2024nr Display Assembly Replacement: étape 2, image 3 de 3
    • Use the opening tool to unsnap the bezel along the hinge cover.
    • Close the laptop and turn it sideways.
    • Separate the bezel along the bottom edge using the opening tool.
    • Remove the bezel and place it aside.
  3. HP 15-dy2024nr Display Assembly Replacement: étape 3, image 1 de 3 HP 15-dy2024nr Display Assembly Replacement: étape 3, image 2 de 3 HP 15-dy2024nr Display Assembly Replacement: étape 3, image 3 de 3
    • Remove the 1.8 mm screws from the top and bottom corners of the screen using a Phillips #1 screwdriver.
    • Use a pair of tweezers to pull out the adhesive tape from the bottom left and right corners of the screen.
    • Remove the LCD and gently place it on the keyboard with both hands.
  4. HP 15-dy2024nr Display Assembly Replacement: étape 4, image 1 de 3 HP 15-dy2024nr Display Assembly Replacement: étape 4, image 2 de 3 HP 15-dy2024nr Display Assembly Replacement: étape 4, image 3 de 3
    • Gently peel off the tape securing the video connector.
    • Disconnect the video cable.
    • Remove the old screen.
2 autres ont terminé cette réparation.
George O.C
Membre depuis le 02/08/24
166 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 50
Total : 121
