Aller au contenu principal
HP 15-dy2024nr Trackpad Replacement
Ce dont vous avez besoin
  1. HP 15-dy2024nr Trackpad Replacement, Back Cover: étape 1, image 1 de 2 HP 15-dy2024nr Trackpad Replacement, Back Cover: étape 1, image 2 de 2
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Trackpad Replacement: étape 2, image 1 de 3 HP 15-dy2024nr Trackpad Replacement: étape 2, image 2 de 3 HP 15-dy2024nr Trackpad Replacement: étape 2, image 3 de 3
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Trackpad Replacement: étape 3, image 1 de 3 HP 15-dy2024nr Trackpad Replacement: étape 3, image 2 de 3 HP 15-dy2024nr Trackpad Replacement: étape 3, image 3 de 3
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
  4. HP 15-dy2024nr Trackpad Replacement, Battery: étape 4, image 1 de 3 HP 15-dy2024nr Trackpad Replacement, Battery: étape 4, image 2 de 3 HP 15-dy2024nr Trackpad Replacement, Battery: étape 4, image 3 de 3
    • Remove five 2.0mm x 3.0mm screws using a Phillips #00 screwdriver.
    • Use the iFixit opening picks to lift the battery away from the laptop.
  5. HP 15-dy2024nr Trackpad Replacement: étape 5, image 1 de 3 HP 15-dy2024nr Trackpad Replacement: étape 5, image 2 de 3 HP 15-dy2024nr Trackpad Replacement: étape 5, image 3 de 3
    • Be aware that the battery is plugged into the motherboard.
    • Unplug the battery from the motherboard.
    • Lift the battery away from the laptop and remove.
  6. HP 15-dy2024nr Trackpad Replacement, Trackpad: étape 6, image 1 de 2 HP 15-dy2024nr Trackpad Replacement, Trackpad: étape 6, image 2 de 2
    • Remove two 3.0 mm screws using a Phillips #1 screwdriver.
    • Lift the metal bracket away from the laptop and remove it with your hands.
  7. HP 15-dy2024nr Trackpad Replacement: étape 7, image 1 de 1
    • Remove three 2.0 mm screws using a Phillips #0 screwdriver.
  8. HP 15-dy2024nr Trackpad Replacement: étape 8, image 1 de 1
    • Lift the track pad away from the laptop and remove with your hands.
Eylandra
Membre depuis le 02/08/24
97 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 56
