Aller au contenu principal
HP 15-dy2702dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP 15-dy2702dx Keyboard Replacement, Lower Case: étape 1, image 1 de 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Keyboard Replacement: étape 2, image 1 de 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Keyboard Replacement: étape 3, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 3, image 2 de 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Keyboard Replacement: étape 4, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 4, image 2 de 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Keyboard Replacement: étape 5, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 5, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 5, image 3 de 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Keyboard Replacement, Battery: étape 6, image 1 de 2 HP 15-dy2702dx Keyboard Replacement, Battery: étape 6, image 2 de 2
    • Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
  7. HP 15-dy2702dx Keyboard Replacement: étape 7, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 7, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 7, image 3 de 3
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
  8. HP 15-dy2702dx Keyboard Replacement, Trackpad: étape 8, image 1 de 1
    • Find the trackpad.
  9. HP 15-dy2702dx Keyboard Replacement: étape 9, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 9, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 9, image 3 de 3
    • Unscrew the two M2x6 Phillips screws securing the trackpad.
  10. HP 15-dy2702dx Keyboard Replacement: étape 10, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 10, image 2 de 2
    • Remove the metal bracket.
  11. HP 15-dy2702dx Keyboard Replacement: étape 11, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 11, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 11, image 3 de 3
    • Lift the black ribbon covering the screws.
    • Unscrew the top three M2x3 Phillips screws.
  12. HP 15-dy2702dx Keyboard Replacement: étape 12, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 12, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 12, image 3 de 3
    • Flip up the locking flap holding the trackpad ribbon in place.
    • Pull the ribbon straight out of its socket.
  13. HP 15-dy2702dx Keyboard Replacement: étape 13, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 13, image 2 de 2
    • Peel back the sticky black strip holding the trackpad in place.
  14. HP 15-dy2702dx Keyboard Replacement: étape 14, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 14, image 2 de 2
    • Remove the trackpad from the laptop.
  15. HP 15-dy2702dx Keyboard Replacement, SSD: étape 15, image 1 de 3 HP 15-dy2702dx Keyboard Replacement, SSD: étape 15, image 2 de 3 HP 15-dy2702dx Keyboard Replacement, SSD: étape 15, image 3 de 3
    • Locate the storage drive.
    • Unscrew the single screw holding the drive in place.
    • The screw is a M2x3 mm Phillips head screw.
  16. HP 15-dy2702dx Keyboard Replacement: étape 16, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 16, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 16, image 3 de 3
    • Grab the drive by its side and gently pull it out.
  17. HP 15-dy2702dx Keyboard Replacement, Fan: étape 17, image 1 de 3 HP 15-dy2702dx Keyboard Replacement, Fan: étape 17, image 2 de 3 HP 15-dy2702dx Keyboard Replacement, Fan: étape 17, image 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the three screws that secure the fan.
    • These screws sizes are M2x6.
  18. HP 15-dy2702dx Keyboard Replacement: étape 18, image 1 de 1
    • Grip the cord that connects the fan to the motherboard and gently pull out to disconnect the cable from the connector.
    • Alternatively, we recommend using a tool to push the connector out of its socket to avoid damaging the wires.
  19. HP 15-dy2702dx Keyboard Replacement: étape 19, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 19, image 2 de 2
    • Gently lift the fan to remove it from the case.
  20. HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: étape 20, image 1 de 3 HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: étape 20, image 2 de 3 HP 15-dy2702dx Keyboard Replacement, Keyboard Assembly: étape 20, image 3 de 3
    • Disconnect all the ribbon cables from the motherboard.
    • Ensure to flip up the locking flaps before attempting to pull the ribbon out.
  21. HP 15-dy2702dx Keyboard Replacement: étape 21, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 21, image 2 de 2
    • Continue disconnecting the ribbon cables.
  22. HP 15-dy2702dx Keyboard Replacement: étape 22, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 22, image 2 de 2
    • Continue disconnecting the remaining ribbons.
  23. HP 15-dy2702dx Keyboard Replacement: étape 23, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 23, image 2 de 2
    • Disconnect the connector.
  24. HP 15-dy2702dx Keyboard Replacement: étape 24, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 24, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 24, image 3 de 3
    • Peel off the black sticker covering the silver connectors near the top of the motherboard.
    • Remove the two silver colored round connector from the motherboard by pulling them up.
    • The connector should have a tag on them with number 1 and 2 on them.
  25. HP 15-dy2702dx Keyboard Replacement: étape 25, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 25, image 2 de 2
    • Pull up on the last connector on the motherboard next to the connectors removed in the previous step.
  26. HP 15-dy2702dx Keyboard Replacement: étape 26, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 26, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 26, image 3 de 3
    • Unscrew all M2x3 Phillips screws holding the motherboard in place.
  27. HP 15-dy2702dx Keyboard Replacement: étape 27, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 27, image 2 de 2
    • Remove the motherboard from the case.
  28. HP 15-dy2702dx Keyboard Replacement: étape 28, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 28, image 2 de 2
    • Unscrew the two M2x3 Phillips screws.
    • Remove the I/O board from the case.
  29. HP 15-dy2702dx Keyboard Replacement: étape 29, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 29, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 29, image 3 de 3
    • Unscrew the three M2x6 Phillips screws from the left metal hinge.
    • Lift the hinge.
  30. HP 15-dy2702dx Keyboard Replacement: étape 30, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 30, image 2 de 2
    • Unscrew the two Phillips screws.
    • One is on the left side near where the fan was removed.
    • The other is near the right laptop metal hinge.
  31. HP 15-dy2702dx Keyboard Replacement: étape 31, image 1 de 2 HP 15-dy2702dx Keyboard Replacement: étape 31, image 2 de 2
    • Remove the black boxes from the case.
    • Disconnect the power cable (white cable with a black flag at the end).
    • The black boxes is still connected to the case through a black wire, do not attempt to remove the wire.
  32. HP 15-dy2702dx Keyboard Replacement: étape 32, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 32, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 32, image 3 de 3
    • Unscrew the three screws on the right-side metal hinge.
    • Lift the hinge.
  33. HP 15-dy2702dx Keyboard Replacement: étape 33, image 1 de 1
    • Remove the power port from the case by pulling it straight up.
  34. HP 15-dy2702dx Keyboard Replacement: étape 34, image 1 de 3 HP 15-dy2702dx Keyboard Replacement: étape 34, image 2 de 3 HP 15-dy2702dx Keyboard Replacement: étape 34, image 3 de 3
    • Remove the keyboard from the laptop.
    • The keyboard is a type where it is directly integrated into the frame so you will need to replace the whole frame.
Zander Herbold
Membre depuis le 09/05/23
646 Réputation
4 tutoriels rédigés
Équipe
Gateway, Team 1-4, Pee Fall 2023 Membre de l'équipe Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 29
Total : 224
