Aller au contenu principal
HP 15-dy2702dx SSD Replacement
Ce dont vous avez besoin
  1. HP 15-dy2702dx SSD Replacement, Lower Case: étape 1, image 1 de 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx SSD Replacement: étape 2, image 1 de 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx SSD Replacement: étape 3, image 1 de 2 HP 15-dy2702dx SSD Replacement: étape 3, image 2 de 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx SSD Replacement: étape 4, image 1 de 2 HP 15-dy2702dx SSD Replacement: étape 4, image 2 de 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx SSD Replacement: étape 5, image 1 de 3 HP 15-dy2702dx SSD Replacement: étape 5, image 2 de 3 HP 15-dy2702dx SSD Replacement: étape 5, image 3 de 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx SSD Replacement, SSD: étape 6, image 1 de 3 HP 15-dy2702dx SSD Replacement, SSD: étape 6, image 2 de 3 HP 15-dy2702dx SSD Replacement, SSD: étape 6, image 3 de 3
    • Locate the storage drive.
    • Unscrew the single screw holding the drive in place.
    • The screw is a M2x3 mm Phillips head screw.
  7. HP 15-dy2702dx SSD Replacement: étape 7, image 1 de 3 HP 15-dy2702dx SSD Replacement: étape 7, image 2 de 3 HP 15-dy2702dx SSD Replacement: étape 7, image 3 de 3
    • Grab the drive by its side and gently pull it out.
Zander Herbold
Membre depuis le 09/05/23
646 Réputation
4 tutoriels rédigés
Équipe
Gateway, Team 1-4, Pee Fall 2023 Membre de l'équipe Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 27
Total : 240
