Aller au contenu principal
HP 15-dy2702dx Trackpad Replacement
Ce dont vous avez besoin
  1. HP 15-dy2702dx Trackpad Replacement, Lower Case: étape 1, image 1 de 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Trackpad Replacement: étape 2, image 1 de 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Trackpad Replacement: étape 3, image 1 de 2 HP 15-dy2702dx Trackpad Replacement: étape 3, image 2 de 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Trackpad Replacement: étape 4, image 1 de 2 HP 15-dy2702dx Trackpad Replacement: étape 4, image 2 de 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Trackpad Replacement: étape 5, image 1 de 3 HP 15-dy2702dx Trackpad Replacement: étape 5, image 2 de 3 HP 15-dy2702dx Trackpad Replacement: étape 5, image 3 de 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Trackpad Replacement, Battery: étape 6, image 1 de 2 HP 15-dy2702dx Trackpad Replacement, Battery: étape 6, image 2 de 2
    • Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
  7. HP 15-dy2702dx Trackpad Replacement: étape 7, image 1 de 3 HP 15-dy2702dx Trackpad Replacement: étape 7, image 2 de 3 HP 15-dy2702dx Trackpad Replacement: étape 7, image 3 de 3
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
  8. HP 15-dy2702dx Trackpad Replacement, Trackpad: étape 8, image 1 de 1
    • Find the trackpad.
  9. HP 15-dy2702dx Trackpad Replacement: étape 9, image 1 de 3 HP 15-dy2702dx Trackpad Replacement: étape 9, image 2 de 3 HP 15-dy2702dx Trackpad Replacement: étape 9, image 3 de 3
    • Unscrew the two M2x6 Phillips screws securing the trackpad.
  10. HP 15-dy2702dx Trackpad Replacement: étape 10, image 1 de 2 HP 15-dy2702dx Trackpad Replacement: étape 10, image 2 de 2
    • Remove the metal bracket.
  11. HP 15-dy2702dx Trackpad Replacement: étape 11, image 1 de 3 HP 15-dy2702dx Trackpad Replacement: étape 11, image 2 de 3 HP 15-dy2702dx Trackpad Replacement: étape 11, image 3 de 3
    • Lift the black ribbon covering the screws.
    • Unscrew the top three M2x3 Phillips screws.
  12. HP 15-dy2702dx Trackpad Replacement: étape 12, image 1 de 3 HP 15-dy2702dx Trackpad Replacement: étape 12, image 2 de 3 HP 15-dy2702dx Trackpad Replacement: étape 12, image 3 de 3
    • Flip up the locking flap holding the trackpad ribbon in place.
    • Pull the ribbon straight out of its socket.
  13. HP 15-dy2702dx Trackpad Replacement: étape 13, image 1 de 2 HP 15-dy2702dx Trackpad Replacement: étape 13, image 2 de 2
    • Peel back the sticky black strip holding the trackpad in place.
  14. HP 15-dy2702dx Trackpad Replacement: étape 14, image 1 de 2 HP 15-dy2702dx Trackpad Replacement: étape 14, image 2 de 2
    • Remove the trackpad from the laptop.
Zander Herbold
Membre depuis le 09/05/23
646 Réputation
4 tutoriels rédigés
Équipe
Gateway, Team 1-4, Pee Fall 2023 Membre de l'équipe Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 6
Total : 57
