Introduction
Your device wont turn on or when running a BIOS/UEFI memory test shows that your SSD is no longer functioning. The Solid State Drive (SSD) is the long storage memory device. When you install a program or save a document this is where that data is stored. Operating system boot files are also located here, and are what allow you to use your device. When the SSD is no longer working properly it should always be replaced.
Ce dont vous avez besoin
Flip the laptop over and open the lid.
Insert an opening tool into the seam between the edge of the lower case and the chassis.
Gently pry around the entire perimeter until the lower case separates from the chassis.
Close the lid and flip the laptop back over.
Remove the lower case.
Remove the single 1 mm screw securing the SSD.
Gently remove the SSD by pulling it directly out of its port.
