Aller au contenu principal
HP 15-f004dx RAM Replacement
Ce dont vous avez besoin
  1. HP 15-f004dx RAM Replacement, RAM: étape 1, image 1 de 1
    • Flip laptop over to the back, so that the stickers are showing and the RAM panel is facing up.
  2. HP 15-f004dx RAM Replacement: étape 2, image 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the two 2mm RAM shield screws from the bottom of the laptop.
  3. HP 15-f004dx RAM Replacement: étape 3, image 1 de 3 HP 15-f004dx RAM Replacement: étape 3, image 2 de 3 HP 15-f004dx RAM Replacement: étape 3, image 3 de 3
    • Remove the RAM shield.
    • Small brackets secure the RAM. Push the brackets to the side to free the RAM.
  4. HP 15-f004dx RAM Replacement: étape 4, image 1 de 2 HP 15-f004dx RAM Replacement: étape 4, image 2 de 2
    • The RAM card should now pop up out of its slot. Remove the RAM.
    • Next, you will replace/reseat the memory modules following steps 3 and 4 in reverse. Once you have completed that, you can now power on the computer to test and see if reseating/replacing the RAM has resolved the problem.
Dylan Kahle
Membre depuis le 09/07/18
351 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 7
Total : 692
