Aller au contenu principal
HP 15-f033wm Battery Replacement
  1. HP 15-f033wm Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. HP 15-f033wm Battery Replacement: étape 2, image 1 de 2 HP 15-f033wm Battery Replacement: étape 2, image 2 de 2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. HP 15-f033wm Battery Replacement: étape 3, image 1 de 2 HP 15-f033wm Battery Replacement: étape 3, image 2 de 2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. HP 15-f033wm Battery Replacement: étape 4, image 1 de 2 HP 15-f033wm Battery Replacement: étape 4, image 2 de 2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. HP 15-f033wm Battery Replacement: étape 5, image 1 de 3 HP 15-f033wm Battery Replacement: étape 5, image 2 de 3 HP 15-f033wm Battery Replacement: étape 5, image 3 de 3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
2 autres ont terminé cette réparation.
Aaron Chabot
Membre depuis le 10/17/17
620 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G4, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 797
