Aller au contenu principal
HP 15-f033wm Power Jack Replacement
Ce dont vous avez besoin
  1. HP 15-f033wm Power Jack Replacement, Battery: étape 1, image 1 de 1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. HP 15-f033wm Power Jack Replacement: étape 2, image 1 de 2 HP 15-f033wm Power Jack Replacement: étape 2, image 2 de 2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. HP 15-f033wm Power Jack Replacement: étape 3, image 1 de 2 HP 15-f033wm Power Jack Replacement: étape 3, image 2 de 2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. HP 15-f033wm Power Jack Replacement: étape 4, image 1 de 2 HP 15-f033wm Power Jack Replacement: étape 4, image 2 de 2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. HP 15-f033wm Power Jack Replacement: étape 5, image 1 de 3 HP 15-f033wm Power Jack Replacement: étape 5, image 2 de 3 HP 15-f033wm Power Jack Replacement: étape 5, image 3 de 3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. HP 15-f033wm Power Jack Replacement, Palm Rest Disassembly: étape 6, image 1 de 1
    • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
  7. HP 15-f033wm Power Jack Replacement: étape 7, image 1 de 1
    • Pry up and detach the keyboard. Starting at the top, slowly work the side and pull the keyboard away from you to unseat the bottom tabs.
  8. HP 15-f033wm Power Jack Replacement: étape 8, image 1 de 1
    • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
  9. HP 15-f033wm Power Jack Replacement: étape 9, image 1 de 2 HP 15-f033wm Power Jack Replacement: étape 9, image 2 de 2
    • Remove the palm rest using the blue spudger tool.
  10. HP 15-f033wm Power Jack Replacement: étape 10, image 1 de 1
    • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
  11. HP 15-f033wm Power Jack Replacement: étape 11, image 1 de 1
    • Remove metal keyboard underlayment.
    • There is no way to separate the palm rest from the keyboard. They both are removed as an assembly.
  12. HP 15-f033wm Power Jack Replacement, Power Jack: étape 12, image 1 de 1
    • After removing the battery and the palm rest, remove the two 7 mm PH1 Phillips head screws holding in the small metal power jack holder.
  13. HP 15-f033wm Power Jack Replacement: étape 13, image 1 de 2 HP 15-f033wm Power Jack Replacement: étape 13, image 2 de 2
    • Unplug the wired connection from the laptop to the power jack.
    • Detach broken power jack using blue spudger.
5 autres ont terminé cette réparation.
Aaron Chabot
Membre depuis le 10/17/17
620 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G4, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G4
3 membres
6 tutoriels rédigés
Un commentaire
I have hp pavilion 15xxxxxx i3 laptop. Its power jack was damaged. I replaced it. When I connected it with power, the light on the jack blinks one time then turned off. Every time I connect it with power, same thing happens. It is neither charging the batyery nor turning the laptop on. Can anyo e tell me what is the issue and how to solve.
Thanks.
AbdulHafeez.
Abdulhafeez Anjum - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 4,390
