Introduction
Technical problems with a motherboard, caused by improper handling, humidity, power supply spikes, or many other reasons, can lead to a great deal of deterioration of user experience. This guide will help you understand the process of replacing the motherboard on the HP 15-f162dx laptop.
Before the start of the replacement process, make sure to disconnect the laptop from its power supply and place the device on a flat work surface with plenty of space around it to avoid mishandling the delicate components.
Ce dont vous avez besoin
Use a Flathead 2.5 mm Phillips screwdriver to remove all of the screws on the backside of the laptop.
There are 14 screws on the back plate in total, make sure to remove them all before proceeding.
