Aller au contenu principal
HP 15-g010dx Button Board Replacement
Ce dont vous avez besoin
  1. HP 15-g010dx Button Board Replacement, Battery: étape 1, image 1 de 1
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Button Board Replacement: étape 2, image 1 de 1
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Button Board Replacement: étape 3, image 1 de 1
    • Pull on the battery to remove.
  4. HP 15-g010dx Button Board Replacement, Keyboard: étape 4, image 1 de 1
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Button Board Replacement: étape 5, image 1 de 1
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Button Board Replacement: étape 6, image 1 de 1
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Button Board Replacement: étape 7, image 1 de 1
    • Release the top of the keyboard.
  8. HP 15-g010dx Button Board Replacement: étape 8, image 1 de 1
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Button Board Replacement, Button Board: étape 9, image 1 de 1
    • Using a Phillips #00 screwdriver, remove all the 5 millimeter screws located on the bottom of the laptop.
  10. HP 15-g010dx Button Board Replacement: étape 10, image 1 de 1
    • Using the spudger, remove the two rubber feet that are located near the battery.
  11. HP 15-g010dx Button Board Replacement: étape 11, image 1 de 1
    • Now remove the two Phillips screws that are located below the rubber feet.
  12. HP 15-g010dx Button Board Replacement: étape 12, image 1 de 3 HP 15-g010dx Button Board Replacement: étape 12, image 2 de 3 HP 15-g010dx Button Board Replacement: étape 12, image 3 de 3
    • Remove the optical drive by pulling it out by hand.
  13. HP 15-g010dx Button Board Replacement: étape 13, image 1 de 1
    • Remove the two Phillips screws inside the optical drive housing.
  14. HP 15-g010dx Button Board Replacement: étape 14, image 1 de 1
    • Disconnect the power button ribbon cable by lifting the connector.
  15. HP 15-g010dx Button Board Replacement: étape 15, image 1 de 1
    • Now disconnect the touch pad ribbon cable by lifting the connector.
  16. HP 15-g010dx Button Board Replacement: étape 16, image 1 de 3 HP 15-g010dx Button Board Replacement: étape 16, image 2 de 3 HP 15-g010dx Button Board Replacement: étape 16, image 3 de 3
    • Remove the screws indicated by an arrow stamped into the metal.
  17. HP 15-g010dx Button Board Replacement: étape 17, image 1 de 1
    • Insert the spudger between the palmrest and the laptop body.
  18. HP 15-g010dx Button Board Replacement: étape 18, image 1 de 1
    • Lift up on palm rest, while working the spudger around the perimeter.
  19. HP 15-g010dx Button Board Replacement: étape 19, image 1 de 2 HP 15-g010dx Button Board Replacement: étape 19, image 2 de 2
    • Remove palm rest and flip it over.
  20. HP 15-g010dx Button Board Replacement: étape 20, image 1 de 2 HP 15-g010dx Button Board Replacement: étape 20, image 2 de 2
    • Release the cable connected to the button board.
  21. HP 15-g010dx Button Board Replacement: étape 21, image 1 de 2 HP 15-g010dx Button Board Replacement: étape 21, image 2 de 2
    • Remove the two Phillips screws securing the button board.
  22. HP 15-g010dx Button Board Replacement: étape 22, image 1 de 1
    • Remove button board.
Ligne d'arrivée
Christopher
Membre depuis le 10/02/18
1 162 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 407
