Aller au contenu principal
HP 15-g010dx Keyboard Ribbon Cable Replacement
Ce dont vous avez besoin
  1. HP 15-g010dx Keyboard Ribbon Cable Replacement, Battery: étape 1, image 1 de 1
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 2, image 1 de 1
    • Place your finger on the left latch and slide it towards the center of the laptop.
  3. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 3, image 1 de 1
    • Pull on the battery to remove.
  4. HP 15-g010dx Keyboard Ribbon Cable Replacement, Keyboard: étape 4, image 1 de 1
    • Remove the two 5 mm screws with the Phillips #00 screwdriver.
  5. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 5, image 1 de 1
    • Using either a credit card or flat spudger, wedge it between the palm rest and the keyboard.
  6. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 6, image 1 de 1
    • Using the tool of your choice, gently pry up on the top of the keyboard.
  7. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 7, image 1 de 1
    • Release the top of the keyboard.
  8. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 8, image 1 de 1
    • Remove the ZIF connector that connects the laptop to the keyboard cable.
  9. HP 15-g010dx Keyboard Ribbon Cable Replacement, Keyboard Ribbon Cable: étape 9, image 1 de 1
    • Gently lift up on the ZIF connector.
  10. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 10, image 1 de 1
    • Now remove the ribbon cable.
  11. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 11, image 1 de 1
    • Check for visible damage on the ribbon cable such as folds, kinks, or corrosion.
  12. HP 15-g010dx Keyboard Ribbon Cable Replacement: étape 12, image 1 de 1
    • Using your pencil's eraser, gently clean the contact points on the ribbon cable.
Ligne d'arrivée
Christopher
Membre depuis le 10/02/18
1 162 Réputation
5 tutoriels rédigés
2 commentaires
my ribbon cable is old, and is not making any good contact, from many times that I have repaired the system, the ribbon cable started not making good contact, because it has inside damage, you know what I mean, it went back and forth many times and it does not want to make good contact, power stops at cable, not board connector
Mitsos Tech Tips - Réponse
I’m the same person, if anyone has the same problem and knows a solution just write it down, I’ll reply as soon as possible
HondaCRX -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 51
Total : 5,391
