Aller au contenu principal
HP 15-g020dx Speaker Replacement
Ce dont vous avez besoin
  1. HP 15-g020dx Speaker Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop over so that the bottom is facing you.
    • Slide the latch towards the center of the laptop so the unlock emblem appears.
  2. HP 15-g020dx Speaker Replacement: étape 2, image 1 de 1
    • Place your finger on the left latch and slide it towards the center of the laptop to remove the battery.
  3. HP 15-g020dx Speaker Replacement: étape 3, image 1 de 1
    • Remove the battery from the laptop.
  4. HP 15-g020dx Speaker Replacement, Keyboard: étape 4, image 1 de 1
    • Use the plastic opening tool to lift the panel with the keyboard.
  5. HP 15-g020dx Speaker Replacement: étape 5, image 1 de 1
    • Take the keyboard and the section of the panel surrounding the keyboard apart.
  6. HP 15-g020dx Speaker Replacement: étape 6, image 1 de 2 HP 15-g020dx Speaker Replacement: étape 6, image 2 de 2
    • Lift the flip covering the connection port and remove the connecting strip to detach the keyboard from the motherboard.
  7. HP 15-g020dx Speaker Replacement, Speaker: étape 7, image 1 de 1
    • Detach the clip on the speaker from the port on the motherboard.
  8. HP 15-g020dx Speaker Replacement: étape 8, image 1 de 1
    • Pull out the wire connecting the two speakers under the motherboard.
  9. HP 15-g020dx Speaker Replacement: étape 9, image 1 de 1
    • Pull the left speaker out and hold the rubber ring.
  10. HP 15-g020dx Speaker Replacement: étape 10, image 1 de 2 HP 15-g020dx Speaker Replacement: étape 10, image 2 de 2
    • Pull the right speaker out and hold the rubber ring.
Ligne d'arrivée
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 257
