Aller au contenu principal
HP 15-g071nr Hard Drive Replacement
Ce dont vous avez besoin
  1. HP 15-g071nr Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP 15-g071nr Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Flip the laptop over so the bottom is facing upwards.
  2. HP 15-g071nr Hard Drive Replacement: étape 2, image 1 de 2 HP 15-g071nr Hard Drive Replacement: étape 2, image 2 de 2
    • Press the tabs at the corners of the laptop at the same time to release the battery.
  3. HP 15-g071nr Hard Drive Replacement: étape 3, image 1 de 3 HP 15-g071nr Hard Drive Replacement: étape 3, image 2 de 3 HP 15-g071nr Hard Drive Replacement: étape 3, image 3 de 3
    • Pull the battery away from the laptop in one motion.
  4. HP 15-g071nr Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Using your Phillips #0 screwdriver, remove all of the screws on the back case.
  5. HP 15-g071nr Hard Drive Replacement: étape 5, image 1 de 3 HP 15-g071nr Hard Drive Replacement: étape 5, image 2 de 3 HP 15-g071nr Hard Drive Replacement: étape 5, image 3 de 3
    • Carefully move the iFixit opening tool along the seam of wrist rest until you can remove it.
    • Remove the wrist rest once it comes loose from the body.
  6. HP 15-g071nr Hard Drive Replacement: étape 6, image 1 de 3 HP 15-g071nr Hard Drive Replacement: étape 6, image 2 de 3 HP 15-g071nr Hard Drive Replacement: étape 6, image 3 de 3
    • Remove the two screws with the Phillips #0.
    • Gently pull the hard drive out of its SATA connection to the motherboard.
    • Attach the loose data cable to the new drive.
    • Be careful not to damage the silver ribbon cable below the hard drive itself.
Emerson Tatelbaum
Membre depuis le 11/01/19
543 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 16
Total : 886
