Aller au contenu principal
HP 15-r137wm TouchSmart CD Drive Replacement
Ce dont vous avez besoin
  1. HP 15-r137wm TouchSmart CD Drive Replacement, Front Panel Assembly: étape 1, image 1 de 3 HP 15-r137wm TouchSmart CD Drive Replacement, Front Panel Assembly: étape 1, image 2 de 3 HP 15-r137wm TouchSmart CD Drive Replacement, Front Panel Assembly: étape 1, image 3 de 3
    • Make sure that the device is powered off and unplugged before removing components.
    • Remove all ten (10) 5.5 mm Phillips #0 screws.
    • Remove the two (2) plastic tabs located at the rear of the panel. Locate the two (2) 7.5mm Phillips #0 screws underneath the pads and remove.
  2. HP 15-r137wm TouchSmart CD Drive Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Use a wide plastic opening tool to pry off the top casing.
    • Be cautious not to crack the casing near the keyboard as it is quite fragile.
    • Lift the cover off carefully as there are wires still attached to internal components.
    • After panel is removed, use an anti-static wrist strap to ensure the motherboard does not get any external shocks from static discharge.
  3. HP 15-r137wm TouchSmart CD Drive Replacement: étape 3, image 1 de 1
    • The connection for the track pad is still connected.
    • Move the keyboard slightly out of the way to locate the connection.
    • Disconnect the small wire protruding from the motherboard underneath the metal plate.
  4. HP 15-r137wm TouchSmart CD Drive Replacement: étape 4, image 1 de 2 HP 15-r137wm TouchSmart CD Drive Replacement: étape 4, image 2 de 2
    • Locate the connection between the power button and the connecting cable.
    • Do not lift the front panel off to far as the cable is still attached.
    • Remove the cable from the motherboard carefully.
  5. HP 15-r137wm TouchSmart CD Drive Replacement, Keyboard: étape 5, image 1 de 2 HP 15-r137wm TouchSmart CD Drive Replacement, Keyboard: étape 5, image 2 de 2
    • Disconnect the connection between the keyboard the the motherboard.
  6. HP 15-r137wm TouchSmart CD Drive Replacement: étape 6, image 1 de 2 HP 15-r137wm TouchSmart CD Drive Replacement: étape 6, image 2 de 2
    • Remove the four (4) 2.5mm by 3.5mm Phillips #0 screws from the metal retaining plate.
    • Lift the metal retaining plate off and away from the device.
  7. HP 15-r137wm TouchSmart CD Drive Replacement, CD Drive: étape 7, image 1 de 2 HP 15-r137wm TouchSmart CD Drive Replacement, CD Drive: étape 7, image 2 de 2
    • Slide the CD drive out slowly by pulling it to the right. There are no screws attached, but there is a connection to the motherboard.
Ross B Jacques
Membre depuis le 10/18/17
857 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G4, Julie Fall 2017 Membre de l'équipe UMass Dartmouth, Team S4-G4, Julie Fall 2017
UMASSD-JULIE-F17S4G4
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 5
Total : 234
