Aller au contenu principal
HP 17-bs049dx Hard Drive Replacement
Ce dont vous avez besoin
  1. HP 17-bs049dx Hard Drive  Replacement, Battery: étape 1, image 1 de 1
    • To remove the battery, simply push the tabs towards each other.
    • The battery will come out with force, be sure to keep anything fragile away from the laptop during this process.
  2. HP 17-bs049dx Hard Drive  Replacement, Back Panel: étape 2, image 1 de 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  3. HP 17-bs049dx Hard Drive  Replacement: étape 3, image 1 de 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  4. HP 17-bs049dx Hard Drive  Replacement: étape 4, image 1 de 2 HP 17-bs049dx Hard Drive  Replacement: étape 4, image 2 de 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  5. HP 17-bs049dx Hard Drive  Replacement: étape 5, image 1 de 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  6. HP 17-bs049dx Hard Drive  Replacement, Hard Drive: étape 6, image 1 de 1
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  7. HP 17-bs049dx Hard Drive  Replacement: étape 7, image 1 de 2 HP 17-bs049dx Hard Drive  Replacement: étape 7, image 2 de 2
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
12 autres ont terminé cette réparation.
Logan McCarty
Membre depuis le 10/01/18
307 Réputation
2 tutoriels rédigés
Équipe
2 commentaires
This was SPOT ON! After searching high and low all over the fricken INTERWEBS for a decent manual, I landed here on your guide and am VERY thankful! KUDOS to you for sharing it!
John Hart - Réponse
How much force am I required to put while lifting the back panel to access the internal components? I can go hulk on it but then I wouldn’t have a laptop later…
Stephanie Rose Brown - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 4,165
