Aller au contenu principal
HP 17-bs049dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP 17-bs049dx Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
    • Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
    • Rubber tabs will require force to access screws.
  2. HP 17-bs049dx Motherboard Replacement: étape 2, image 1 de 1
    • Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
  3. HP 17-bs049dx Motherboard Replacement: étape 3, image 1 de 2 HP 17-bs049dx Motherboard Replacement: étape 3, image 2 de 2
    • Pull outwards on the disk reader to remove from main frame.
    • This removal will require force.
    • All screws must be removed before removing disk reader.
  4. HP 17-bs049dx Motherboard Replacement: étape 4, image 1 de 1
    • Lift back panel to access internal components.
    • You will need to use force to pry it open.
  5. HP 17-bs049dx Motherboard Replacement, Hard Drive: étape 5, image 1 de 1
    • Remove screw (7.51mm) on USB port with "Phillips 0 Screwdriver".
    • Lift the USB port over and away from hard drive.
  6. HP 17-bs049dx Motherboard Replacement: étape 6, image 1 de 2 HP 17-bs049dx Motherboard Replacement: étape 6, image 2 de 2
    • Lift rubber black tabs located on the hard drive upwards.
    • Disconnect hard drive from motherboard by pulling towards you.
  7. HP 17-bs049dx Motherboard Replacement, Motherboard: étape 7, image 1 de 3 HP 17-bs049dx Motherboard Replacement, Motherboard: étape 7, image 2 de 3 HP 17-bs049dx Motherboard Replacement, Motherboard: étape 7, image 3 de 3
    • Make sure to unplug everything connected to the motherboard.
    • Be gentle with this step.
  8. HP 17-bs049dx Motherboard Replacement: étape 8, image 1 de 1
    • Remove the screws (7.51mm) with a Phillips #0 screwdriver.
    • Once all of the screws are removed, remove the motherboard from the device.
Chanceline Mbiaoh
Membre depuis le 09/26/18
207 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 16
Total : 815
