Aller au contenu principal
HP 17-x027ds Hard Drive Replacement
Ce dont vous avez besoin
  1. HP 17-x027ds Hard Drive Replacement, Battery: étape 1, image 1 de 3 HP 17-x027ds Hard Drive Replacement, Battery: étape 1, image 2 de 3 HP 17-x027ds Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Flip the laptop so you can see the serial number and the four 7mm screws in all the corners.
    • Click the hinges by pushing them inward, which are located at the top of the laptop.
    • Remove the battery by pulling it out.
  2. HP 17-x027ds Hard Drive Replacement, Hard Drive: étape 2, image 1 de 3 HP 17-x027ds Hard Drive Replacement, Hard Drive: étape 2, image 2 de 3 HP 17-x027ds Hard Drive Replacement, Hard Drive: étape 2, image 3 de 3
    • Remove the two pieces of black tape that are each covering a 7mm screw at the top corners of the laptop.
    • When removing the two black pieces of tape, keep the tape so you can place it back on the laptop again when reassembling.
    • Remove the fourteen 7mm JIS #1 screws.
  3. HP 17-x027ds Hard Drive Replacement: étape 3, image 1 de 2 HP 17-x027ds Hard Drive Replacement: étape 3, image 2 de 2
    • Lift the bottom cover of the laptop with a metal spudger by wedging the sides first and going all around.
    • The cover is difficult to lift, so use extreme force.
  4. HP 17-x027ds Hard Drive Replacement: étape 4, image 1 de 3 HP 17-x027ds Hard Drive Replacement: étape 4, image 2 de 3 HP 17-x027ds Hard Drive Replacement: étape 4, image 3 de 3
    • Disconnect the blue ends of the white ribbon cable by pulling the blue ends out of the connector.
    • The ribbon cable will still be connected to the rubber and just the ends will be disconnected.
  5. HP 17-x027ds Hard Drive Replacement: étape 5, image 1 de 2 HP 17-x027ds Hard Drive Replacement: étape 5, image 2 de 2
    • Lift the black rubber cover containing the hard drive by lifting the right side of the rubber cover.
    • The white ribbon cable will still be connected to the rubber cover, so remove the hard drive out from under.
Bill Hoang
Membre depuis le 09/18/18
452 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 12
Total : 1,064
