Aller au contenu principal
HP 17-x116dx Space bar key Replacement
Ce dont vous avez besoin
  1. HP 17-x116dx Space bar key Replacement, Space Bar Key: étape 1, image 1 de 1
    • Locate the spacebar key.
  2. HP 17-x116dx Space bar key Replacement: étape 2, image 1 de 1
    • At the edge of the space bay key use a spudger to help with the removal.
  3. HP 17-x116dx Space bar key Replacement: étape 3, image 1 de 1
    • Slide the spudger under the spacebar key.
  4. HP 17-x116dx Space bar key Replacement: étape 4, image 1 de 1
    • The left side of the spacebar key will start lifting up. At this point you can remove the spacebar key.
  5. HP 17-x116dx Space bar key Replacement: étape 5, image 1 de 1
    • During this point you can carefully take off the spacebar key.
  6. HP 17-x116dx Space bar key Replacement: étape 6, image 1 de 1
    • you will notice a metal bars along the rim these metal bars is what connects the bottom surface together.
  7. HP 17-x116dx Space bar key Replacement: étape 7, image 1 de 1
    • Dust off any dirt that could be under there.
  8. HP 17-x116dx Space bar key Replacement: étape 8, image 1 de 1
    • The lower edge of the keyboard has two plastic notches on either side.
  9. HP 17-x116dx Space bar key Replacement: étape 9, image 1 de 1
    • slide the bracket into the space below the spacebar to carefully place it back.
  10. HP 17-x116dx Space bar key Replacement: étape 10, image 1 de 1
    • The Spacebar key will be working once you can press down and it will type a space.
Liliana Chuc
Membre depuis le 03/22/18
281 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team S17-G1, Blackburne Spring 2018 Membre de l'équipe Sam Houston State, Team S17-G1, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 940
