Aller au contenu principal
HP 17-x173dx CPU Cooling Fan Replacement
Ce dont vous avez besoin
  1. HP 17-x173dx CPU Cooling Fan Replacement, Battery: étape 1, image 1 de 2 HP 17-x173dx CPU Cooling Fan Replacement, Battery: étape 1, image 2 de 2
    • Begin by sliding the left tab to the unlock position
  2. HP 17-x173dx CPU Cooling Fan Replacement: étape 2, image 1 de 1
    • Push each of the two tabs in the direction specified by the picture.
  3. HP 17-x173dx CPU Cooling Fan Replacement: étape 3, image 1 de 3 HP 17-x173dx CPU Cooling Fan Replacement: étape 3, image 2 de 3 HP 17-x173dx CPU Cooling Fan Replacement: étape 3, image 3 de 3
    • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
  4. HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: étape 4, image 1 de 2 HP 17-x173dx CPU Cooling Fan Replacement, CPU Cooling Fan: étape 4, image 2 de 2
    • Use a spudger or Jimmy to lift the plastic back cover starting from the back right side near the vents.
    • Remove the back cover of the device by continuing to lift the plastic around the entire perimeter of the device.
  5. HP 17-x173dx CPU Cooling Fan Replacement: étape 5, image 1 de 3 HP 17-x173dx CPU Cooling Fan Replacement: étape 5, image 2 de 3 HP 17-x173dx CPU Cooling Fan Replacement: étape 5, image 3 de 3
    • Using the Phillips #0 screwdriver, unscrew four heat-sink screws (These will unscrew, but will stay attached to the heat-sink), and one screw towards the top.
    • Disconnect the power cable.
  6. HP 17-x173dx CPU Cooling Fan Replacement: étape 6, image 1 de 2 HP 17-x173dx CPU Cooling Fan Replacement: étape 6, image 2 de 2
    • Remove the CPU cooling fan.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 373
