Aller au contenu principal
HP 17-x173dx Optical Disk Drive Replacement
Ce dont vous avez besoin
  1. HP 17-x173dx Optical Disk Drive Replacement, Optical Disk Drive: étape 1, image 1 de 1
    • Start by placing the laptop with its bottom facing up.
    • Using the Phillips #0 screwdriver, remove the single 7 mm screw that holds the disk drive in place.
  2. HP 17-x173dx Optical Disk Drive Replacement: étape 2, image 1 de 2 HP 17-x173dx Optical Disk Drive Replacement: étape 2, image 2 de 2
    • Use a spudger or thin item to apply outward pressure between the disk drive opening and the device to remove the optical disk drive. You may be able to remove it using your fingernail.
Insert new optical drive. To reassemble your device, follow these instructions in reverse order.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 5
Total : 226
