Aller au contenu principal
HP 17-x173dx RAM Replacement
Ce dont vous avez besoin
  1. HP 17-x173dx RAM Replacement, Battery: étape 1, image 1 de 2 HP 17-x173dx RAM Replacement, Battery: étape 1, image 2 de 2
    • Begin by sliding the left tab to the unlock position
  2. HP 17-x173dx RAM Replacement: étape 2, image 1 de 1
    • Push each of the two tabs in the direction specified by the picture.
  3. HP 17-x173dx RAM Replacement: étape 3, image 1 de 3 HP 17-x173dx RAM Replacement: étape 3, image 2 de 3 HP 17-x173dx RAM Replacement: étape 3, image 3 de 3
    • Slide and hold the right tab to the left, while gently pushing out the battery with your thumbs
  4. HP 17-x173dx RAM Replacement, RAM: étape 4, image 1 de 1
    • Using the Phillips #0 screwdriver, remove fourteen 7 mm screws on the back of the device (two will be underneath where the battery was).
  5. HP 17-x173dx RAM Replacement: étape 5, image 1 de 3 HP 17-x173dx RAM Replacement: étape 5, image 2 de 3 HP 17-x173dx RAM Replacement: étape 5, image 3 de 3
    • Remove the Optical Disk Drive.
    • Use the spudger to lift the plastic backing, starting from the back right side, near the vent.
    • Remove the back of the device by continuing to lift the plastic around the entire perimeter of the device.
  6. HP 17-x173dx RAM Replacement: étape 6, image 1 de 3 HP 17-x173dx RAM Replacement: étape 6, image 2 de 3 HP 17-x173dx RAM Replacement: étape 6, image 3 de 3
    • Use a pair of tweezers or your fingernails to carefully pry the two metal retention clips out and away from the ram casing.
    • Then gently bend the plastic retainers away to free the ram stick.
  7. HP 17-x173dx RAM Replacement: étape 7, image 1 de 2 HP 17-x173dx RAM Replacement: étape 7, image 2 de 2
    • Lift the RAM stick away from the motherboard and remove it from the device.
    • Repeat this step for any extra sticks of RAM.
Install your replacement RAM and reassemble your device by following these instructions in reverse order.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 16
Total : 731
