Introduction
If your laptop slows down when using certain applications, you may need to replace or add RAM in an HP 17-x173dx. This guide will show you how to replace RAM in your laptop in easy-to-follow steps.
Ce dont vous avez besoin
Using the Phillips #0 screwdriver, remove fourteen 7 mm screws on the back of the device (two will be underneath where the battery was).
Install your replacement RAM and reassemble your device by following these instructions in reverse order.
