Aller au contenu principal
HP 7 PLUS 1301 Battery Replacement
Ce dont vous avez besoin
  1. HP 7 PLUS 1301 Battery Replacement, Battery: étape 1, image 1 de 2 HP 7 PLUS 1301 Battery Replacement, Battery: étape 1, image 2 de 2
    • Make sure the device is off and not plugged in before starting.
    • Using the Torx T5 screwdriver, remove the 3mm screws on all 4 corners of the device.
  2. HP 7 PLUS 1301 Battery Replacement: étape 2, image 1 de 2 HP 7 PLUS 1301 Battery Replacement: étape 2, image 2 de 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Battery Replacement: étape 3, image 1 de 2 HP 7 PLUS 1301 Battery Replacement: étape 3, image 2 de 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Battery Replacement: étape 4, image 1 de 2 HP 7 PLUS 1301 Battery Replacement: étape 4, image 2 de 2
    • Push out the connector to disconnect the battery.
    • Move the battery connector clear of the connector socket.
  5. HP 7 PLUS 1301 Battery Replacement: étape 5, image 1 de 1
    • Carefully remove the battery by sliding a plastic spudger under the battery. Use an adhesive remover if available under the battery to make it easier for the battery to come off.
Adanna Ilori
Membre depuis le 02/05/19
301 Réputation
2 tutoriels rédigés
Équipe
UC Davis, Team S20-G6, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 749
