Aller au contenu principal
HP 7 PLUS 1301 Speaker Replacement
Ce dont vous avez besoin
  1. HP 7 PLUS 1301 Speaker Replacement, Speaker: étape 1, image 1 de 2 HP 7 PLUS 1301 Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Make sure the device is off and not plugged in before starting.
    • Use the Torx T5 screwdriver and remove the 3mm screws on all four corners of the device.
  2. HP 7 PLUS 1301 Speaker Replacement: étape 2, image 1 de 2 HP 7 PLUS 1301 Speaker Replacement: étape 2, image 2 de 2
    • Using the plastic opening tool, push in between the front, then slide it around.
    • Slide the plastic opening tool all the way around the tablet to separate the back cover.
    • Be careful when trying to remove the back as the screen can be damaged with excessive force.
  3. HP 7 PLUS 1301 Speaker Replacement: étape 3, image 1 de 2 HP 7 PLUS 1301 Speaker Replacement: étape 3, image 2 de 2
    • Continue sliding the plastic opening tool around the tablet until the cover fully separates from the device.
    • Remove the back cover.
  4. HP 7 PLUS 1301 Speaker Replacement: étape 4, image 1 de 2 HP 7 PLUS 1301 Speaker Replacement: étape 4, image 2 de 2
    • Using tweezers, carefully remove the speaker connector from the socket.
  5. HP 7 PLUS 1301 Speaker Replacement: étape 5, image 1 de 3 HP 7 PLUS 1301 Speaker Replacement: étape 5, image 2 de 3 HP 7 PLUS 1301 Speaker Replacement: étape 5, image 3 de 3
    • Insert a spudger in the bottom right of the speaker. It makes the speaker easier to come off.
    • Carefully remove the speaker with your hand.
    • Some force needs to be applied here due to the adhesive on the other side of the speaker.
Shao-Hung Hsiao
Membre depuis le 02/05/19
201 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S20-G6, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G6, Lore Winter 2019
UCD-LORE-W19S20G6
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 112
