Aller au contenu principal
HP 8 1401 Front-Facing Camera Replacement
Ce dont vous avez besoin
  1. HP 8 1401 Front-Facing Camera Replacement, Back Panel: étape 1, image 1 de 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP 8 1401 Front-Facing Camera Replacement: étape 2, image 1 de 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP 8 1401 Front-Facing Camera Replacement: étape 3, image 1 de 2 HP 8 1401 Front-Facing Camera Replacement: étape 3, image 2 de 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP 8 1401 Front-Facing Camera Replacement, Front-Facing Camera: étape 4, image 1 de 1
    • Place the tip of your spudger under the edge of the press fit connector, and pry the connector straight up from its socket.
  5. HP 8 1401 Front-Facing Camera Replacement: étape 5, image 1 de 2 HP 8 1401 Front-Facing Camera Replacement: étape 5, image 2 de 2
    • Lift the front-facing camera out of the tablet.
  6. HP 8 1401 Front-Facing Camera Replacement: étape 6, image 1 de 1
    • After the front-facing camera has been removed, the tablet should look like this.
Katie Presz
Membre depuis le 01/16/19
641 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 138
