Aller au contenu principal
HP Beats Special Edition 15-p390nr Fan Replacement
Ce dont vous avez besoin
  1. HP Beats Special Edition 15-p390nr Fan Replacement, Keyboard: étape 1, image 1 de 2 HP Beats Special Edition 15-p390nr Fan Replacement, Keyboard: étape 1, image 2 de 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Fan Replacement: étape 2, image 1 de 2 HP Beats Special Edition 15-p390nr Fan Replacement: étape 2, image 2 de 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Fan Replacement: étape 3, image 1 de 2 HP Beats Special Edition 15-p390nr Fan Replacement: étape 3, image 2 de 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Fan Replacement: étape 4, image 1 de 2 HP Beats Special Edition 15-p390nr Fan Replacement: étape 4, image 2 de 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Fan Replacement: étape 5, image 1 de 2 HP Beats Special Edition 15-p390nr Fan Replacement: étape 5, image 2 de 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Fan Replacement: étape 6, image 1 de 2 HP Beats Special Edition 15-p390nr Fan Replacement: étape 6, image 2 de 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
  7. HP Beats Special Edition 15-p390nr Fan Replacement, Motherboard: étape 7, image 1 de 1
    • Remove screws from the motherboard.
    • 11 screws should be removed from the motherboard
  8. HP Beats Special Edition 15-p390nr Fan Replacement: étape 8, image 1 de 1
    • Unclamp wire strips from motherboard.
  9. HP Beats Special Edition 15-p390nr Fan Replacement: étape 9, image 1 de 1
    • Detach by lifting the motherboard up and flip the motherboard over.
  10. HP Beats Special Edition 15-p390nr Fan Replacement: étape 10, image 1 de 1
    • Unclip wifi card for further procedures
  11. HP Beats Special Edition 15-p390nr Fan Replacement, Fan: étape 11, image 1 de 1
    • Remove the fan cable from the connector that connects to the motherboard.
    • Pull straight out to avoid damage to connectors.
  12. HP Beats Special Edition 15-p390nr Fan Replacement: étape 12, image 1 de 1
    • Remove all three screws that hold the fan to the system board
  13. HP Beats Special Edition 15-p390nr Fan Replacement: étape 13, image 1 de 1
    • Lift and remove the fan from the top cover.
Evan Rice
Membre depuis le 10/02/18
506 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 20
Total : 2,645
