Aller au contenu principal
HP Beats Special Edition 15-p390nr Keyboard Replacement
Ce dont vous avez besoin
  1. HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: étape 1, image 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Turn computer off before starting.
    • Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
  2. HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 2, image 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 2, image 2 de 2
    • Some screws may be hidden under a screw cover.
    • Simply use a metal spudger to pop off the screw cover to unveil the hidden 8mm screw.
    • Screw cover may fly when removing.
  3. HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 3, image 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 3, image 2 de 2
    • Once screws are removed you may now remove the optical drive.
    • Remove the hidden 3mm screw in the optical drive port.
  4. HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 4, image 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 4, image 2 de 2
    • Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
    • Popping noises are normal.
    • The shoulder caps are removable. Underneath there are 2 additional screws.
  5. HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 5, image 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 5, image 2 de 2
    • Flip computer over and wedge metal spudger along the computer to pop off keyboard panel
  6. HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 6, image 1 de 2 HP Beats Special Edition 15-p390nr Keyboard Replacement: étape 6, image 2 de 2
    • Unclip wires connected to the motherboard and remove keyboard from the device.
    • 17 screws should be removed up to this point.
4 autres ont terminé cette réparation.
Deziree Mascarenas
Membre depuis le 10/04/18
499 Réputation
3 tutoriels rédigés
Un commentaire
Can you add if we can take trackpad off the keyboard
Paul Schupbach - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 38
Total : 2,806
