Aller au contenu principal
HP Chromebook 11 G4 SD Card Reader Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G4 SD Card Reader Replacement, Keyboard: étape 1, image 1 de 1
    • Position the closed Chromebook with the rubber pads are facing up.
  2. HP Chromebook 11 G4 SD Card Reader Replacement: étape 2, image 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: étape 2, image 2 de 2
    • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
    • Pry off the rubber pads to reveal a screw under each pad.
    • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
  3. HP Chromebook 11 G4 SD Card Reader Replacement: étape 3, image 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: étape 3, image 2 de 2
    • Remove the eleven 6mm Phillips #1 screws.
  4. HP Chromebook 11 G4 SD Card Reader Replacement: étape 4, image 1 de 1
    • Flip over the Chromebook and open it.
  5. HP Chromebook 11 G4 SD Card Reader Replacement: étape 5, image 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: étape 5, image 2 de 2
    • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
    • Slide the spudger along the gap, applying downward pressure to separate the two components.
    • You should hear popping sounds as you slide the spudger along the edge.
    • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
  6. HP Chromebook 11 G4 SD Card Reader Replacement: étape 6, image 1 de 1
    • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
  7. HP Chromebook 11 G4 SD Card Reader Replacement: étape 7, image 1 de 3 HP Chromebook 11 G4 SD Card Reader Replacement: étape 7, image 2 de 3 HP Chromebook 11 G4 SD Card Reader Replacement: étape 7, image 3 de 3
    • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
    • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
  8. HP Chromebook 11 G4 SD Card Reader Replacement: étape 8, image 1 de 1
    • Remove the keyboard assembly by lifting it off the laptop base.
  9. HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: étape 9, image 1 de 3 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: étape 9, image 2 de 3 HP Chromebook 11 G4 SD Card Reader Replacement, SD Card Reader: étape 9, image 3 de 3
    • Flip up the flap on the ZIP connector with your finger.
    • Gently pull out the ribbon cable.
  10. HP Chromebook 11 G4 SD Card Reader Replacement: étape 10, image 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: étape 10, image 2 de 2
    • Remove the two 4 mm Phillips #1 screws.
  11. HP Chromebook 11 G4 SD Card Reader Replacement: étape 11, image 1 de 2 HP Chromebook 11 G4 SD Card Reader Replacement: étape 11, image 2 de 2
    • Lift the ribbon cable back and out of the way.
    • Pull out the SD card reader.
2 autres ont terminé cette réparation.
Jair Herrera
Membre depuis le 04/26/17
694 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S16-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S16-G5, Banghart Winter 2018
CPSU-BANGHART-W18S16G5
5 membres
15 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 1,033
