Aller au contenu principal
HP Chromebook 11 G5 Battery Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G5 Battery Replacement, Keyboard: étape 1, image 1 de 1
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 Battery Replacement: étape 2, image 1 de 1
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 Battery Replacement: étape 3, image 1 de 1
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 Battery Replacement: étape 4, image 1 de 1
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 Battery Replacement: étape 5, image 1 de 1
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 Battery Replacement: étape 6, image 1 de 1
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 Battery Replacement: étape 7, image 1 de 1
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 Battery Replacement: étape 8, image 1 de 1
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 Battery Replacement, Battery: étape 9, image 1 de 1
    • Remove the two wires from the top of the WLAN module by pulling them gently with a spudger or your hand and snapping the wires out of place.
  10. HP Chromebook 11 G5 Battery Replacement: étape 10, image 1 de 2 HP Chromebook 11 G5 Battery Replacement: étape 10, image 2 de 2
    • Remove the battery connector by pushing both edges outward using the sharp end of the spudger.
  11. HP Chromebook 11 G5 Battery Replacement: étape 11, image 1 de 2 HP Chromebook 11 G5 Battery Replacement: étape 11, image 2 de 2
    • Remove the ribbon cable from the connector board by lifting the cover with the sharp end of the spudger and gently pulling the cable out with your hand.
    • Ribbon cables can be fragile and extra care must be taken when pulling the cable out of the connector.
  12. HP Chromebook 11 G5 Battery Replacement: étape 12, image 1 de 1
    • Remove the two 3mm silver screws from the battery using a Phillips #00 screwdriver.
    • Remove the black 4mm screw with the Phillips #00 screwdriver.
    • Remove the battery by hand.
    • Be cautious when removing the battery as two WLAN cables run along the top edge of it.
4 autres ont terminé cette réparation.
Kunal Chopra
Membre depuis le 01/14/20
474 Réputation
2 tutoriels rédigés
Équipe
York University, Team S1-G3, Woodhouse Winter 2020 Membre de l'équipe York University, Team S1-G3, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 27
Total : 1,131
