Aller au contenu principal
HP Chromebook 11 G5 Screen Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G5 Screen Replacement, Screen: étape 1, image 1 de 2 HP Chromebook 11 G5 Screen Replacement, Screen: étape 1, image 2 de 2
    • Open the lid as far as possible.
    • Slide your spudger into the bezel of the laptop until it appears on the other side.
    • Make your way around the bezel with the spudger while gently prying up the bezel to snap it out of place.
    • You should hear an audible click when the snap is removed.
    • Make sure there is a gap between the spudger and the components behind the bezel while prying.
  2. HP Chromebook 11 G5 Screen Replacement: étape 2, image 1 de 2 HP Chromebook 11 G5 Screen Replacement: étape 2, image 2 de 2
    • Hold the bezel on both sides, and twist the bezel repeatedly until the bottom bezel snaps out of place.
    • This step is likely the most difficult, and you may have to use additional force to remove the bezel.
  3. HP Chromebook 11 G5 Screen Replacement: étape 3, image 1 de 2 HP Chromebook 11 G5 Screen Replacement: étape 3, image 2 de 2
    • Unscrew the four silver 4mm Phillips #0 screws on the edges of the display.
    • To ensure that the LCD panel does not immediately slide down upon removing the screws, make sure the display is still tilted as far back as possible.
  4. HP Chromebook 11 G5 Screen Replacement: étape 4, image 1 de 2 HP Chromebook 11 G5 Screen Replacement: étape 4, image 2 de 2
    • Gently lift the LCD panel out of the body and lower it onto the keyboard deck.
    • Ensure that the power button is not accidentally pressed while lowering the display.
  5. HP Chromebook 11 G5 Screen Replacement: étape 5, image 1 de 3 HP Chromebook 11 G5 Screen Replacement: étape 5, image 2 de 3 HP Chromebook 11 G5 Screen Replacement: étape 5, image 3 de 3
    • Identify the eDP 30-pin connector and use the sharp end of the spudger to peel off a corner of the tape over the connector.
    • To avoid damaging internal components, only use a metal spudger as a last resort.
    • Use your fingers to peel off the rest of the tape.
    • Peel the tape slowly to ensure that the connector does not get pulled while peeling the tape.
  6. HP Chromebook 11 G5 Screen Replacement: étape 6, image 1 de 1
    • Hold both sides of the tape and gently push back the connector to disconnect the display.
    • When attaching the new display, make sure there is no gap between the connector and its socket.
    • Two audible clicks should be heard when the connector is reattached, one click for each side of the connector.
2 autres ont terminé cette réparation.
Kunal Chopra
Membre depuis le 01/14/20
474 Réputation
2 tutoriels rédigés
Équipe
York University, Team S1-G3, Woodhouse Winter 2020 Membre de l'équipe York University, Team S1-G3, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 36
Total : 1,189
