Introduction
Before starting any repairs you should go through the process of troubleshooting your device first. Once you have determined the problem will be fixed with a replacement of a component then you can take a look at this guide. This is a guide on how to replace the keyboard & touchpad assembly on the HP Chromebook 11A G8 EE.
Ce dont vous avez besoin
Use a Phillips #1 screwdriver to remove:
Four 7 mm screws.
Two 8 mm screws.
Presque terminé !
