Aller au contenu principal
HP Chromebook 11 G8 EE Screen Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11 G8 EE Screen Replacement, Keyboard & Touchpad Assembly: étape 1, image 1 de 1
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Screen Replacement: étape 2, image 1 de 2 HP Chromebook 11 G8 EE Screen Replacement: étape 2, image 2 de 2
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Screen Replacement: étape 3, image 1 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 3, image 2 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Screen Replacement, Bezel: étape 4, image 1 de 2 HP Chromebook 11 G8 EE Screen Replacement, Bezel: étape 4, image 2 de 2
    • Using your hands, pry off the hinge cover by lifting it.
  5. HP Chromebook 11 G8 EE Screen Replacement: étape 5, image 1 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 5, image 2 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 5, image 3 de 3
    • Using the opening tool, pry the bezel away from the top case.
    • It requires a bit of force; you aren't going to break it!
  6. HP Chromebook 11 G8 EE Screen Replacement: étape 6, image 1 de 1
    • Pull the bezel toward you.
    • Peel it away from the screen gently.
  7. HP Chromebook 11 G8 EE Screen Replacement: étape 7, image 1 de 1
    • Completely remove the bezel.
  8. HP Chromebook 11 G8 EE Screen Replacement, Screen: étape 8, image 1 de 1
    • Remove the four 3.5 mm screws with a Phillips #1 screwdriver.
  9. HP Chromebook 11 G8 EE Screen Replacement: étape 9, image 1 de 1
    • Flip the screen toward you.
  10. HP Chromebook 11 G8 EE Screen Replacement: étape 10, image 1 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 10, image 2 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 10, image 3 de 3
    J'achète
    • Use tweezers to peel away the black tape holding the connector.
  11. HP Chromebook 11 G8 EE Screen Replacement: étape 11, image 1 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 11, image 2 de 3 HP Chromebook 11 G8 EE Screen Replacement: étape 11, image 3 de 3
    • Use the tweezers to pull away the tan tape.
    • You should see the colored wires of the connector.
  12. HP Chromebook 11 G8 EE Screen Replacement: étape 12, image 1 de 2 HP Chromebook 11 G8 EE Screen Replacement: étape 12, image 2 de 2
    • Using the tweezers, lift up the small red latch on the connector.
    • Pull off the connector.
  13. HP Chromebook 11 G8 EE Screen Replacement: étape 13, image 1 de 1
    • Remove the screen.
Isabella Brown
Membre depuis le 10/25/22
312 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 4-2, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G2
5 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 85
Total : 876
