Aller au contenu principal
HP Chromebook 14 G5 Motherboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14 G5 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 Motherboard Replacement: étape 2, image 1 de 1
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 Motherboard Replacement: étape 3, image 1 de 2 HP Chromebook 14 G5 Motherboard Replacement: étape 3, image 2 de 2
    • Then you can see the motherboard marked in the yellow rectangle.
    • Unscrew the 4.1mm screws around the motherboard using the Phillips #00 screwdriver.
  4. HP Chromebook 14 G5 Motherboard Replacement: étape 4, image 1 de 2 HP Chromebook 14 G5 Motherboard Replacement: étape 4, image 2 de 2
    • Disconnect the two Flexible Flat Cable (FFC) from the device.
  5. HP Chromebook 14 G5 Motherboard Replacement: étape 5, image 1 de 1
    • Remove the motherboard from the device.
We omitted some photos of reassembling the device. For this part, follow these instructions in reverse order.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 19
Total : 1,167
