Aller au contenu principal
HP Chromebook 14 G5 SD card reader Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14 G5 SD card reader Replacement, SD card reader: étape 1, image 1 de 1
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
  2. HP Chromebook 14 G5 SD card reader Replacement: étape 2, image 1 de 1
    • Open the back cover using a spudger.
  3. HP Chromebook 14 G5 SD card reader Replacement: étape 3, image 1 de 1
    • Now we can see the SD card reader (in the yellow rectangle) that we need to tear down.
  4. HP Chromebook 14 G5 SD card reader Replacement: étape 4, image 1 de 1
    • Remove the three 2mm screws around the SD card reader using the Phillips #00 Screwdriver.
  5. HP Chromebook 14 G5 SD card reader Replacement: étape 5, image 1 de 2 HP Chromebook 14 G5 SD card reader Replacement: étape 5, image 2 de 2
    • Disconnect the Flexible Flat Cable (FFC) from the motherboard.
  6. HP Chromebook 14 G5 SD card reader Replacement: étape 6, image 1 de 1
    • Remove the SD card reader the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 7
Total : 293
