Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: étape 1, image 1 de 2 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement, Keyboard and Touchpad: étape 1, image 2 de 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
  2. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 2, image 1 de 3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 2, image 2 de 3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 2, image 3 de 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 3, image 1 de 3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 3, image 2 de 3 HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 3, image 3 de 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 4, image 1 de 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX Keyboard and Touchpad Replacement: étape 5, image 1 de 1
    • Set aside the detached keyboard.
17 autres ont terminé cette réparation.
Wilfredo Ramos
Membre depuis le 01/28/15
626 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 17-2, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 membres
8 tutoriels rédigés
10 commentaires de tutoriel
In the black variant of this model I found that there are two screws under the rubber feet near the hinge.
Justin Cowen - Réponse Partager
Super easy repair, keep track of your screws and be very careful with ribbon that connects keyboard and Touch pad.
Terry - Réponse Partager
This was very close to a similar HP Chromebook I had to repair recently. Such a beautiful and simple process. I cleaned the keyboard connectors and everything functioned perfectly after I was done. The whole process took about 30 minutes (allotting 10 minutes to find my rubbing alcohol that my wife hid from me).
Josh Bollman - Réponse Partager
Any idea how to get the replacement keyboard?
Pawel Wozniak - Réponse Partager
At the top of this page under "Relevant parts" there is a link to purchase the keyboard replacement.
Kevin Piper - Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 83
Total : 16,656
