Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP Chromebook 14-Q010DX Motherboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: étape 1, image 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: étape 1, image 2 de 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Demander à FixBot
    Ajouter un commentaire
  2. HP Chromebook 14-Q010DX Motherboard Replacement: étape 2, image 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 2, image 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 2, image 3 de 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Demander à FixBot
  3. HP Chromebook 14-Q010DX Motherboard Replacement: étape 3, image 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 3, image 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 3, image 3 de 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Demander à FixBot
  4. HP Chromebook 14-Q010DX Motherboard Replacement: étape 4, image 1 de 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Demander à FixBot
  5. HP Chromebook 14-Q010DX Motherboard Replacement: étape 5, image 1 de 1
    • Set aside the detached keyboard.
    Demander à FixBot
  6. HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: étape 6, image 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: étape 6, image 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: étape 6, image 3 de 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    Demander à FixBot
  7. HP Chromebook 14-Q010DX Motherboard Replacement: étape 7, image 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement: étape 7, image 2 de 2
    • Gently remove the speakers.
    Demander à FixBot
  8. HP Chromebook 14-Q010DX Motherboard Replacement, Battery: étape 8, image 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Battery: étape 8, image 2 de 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    Demander à FixBot
  9. HP Chromebook 14-Q010DX Motherboard Replacement: étape 9, image 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 9, image 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 9, image 3 de 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    Demander à FixBot
  10. HP Chromebook 14-Q010DX Motherboard Replacement: étape 10, image 1 de 1
    • Gently remove battery.
    Demander à FixBot
  11. HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: étape 11, image 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: étape 11, image 2 de 2
    • Using a spudger, remove the white and black cables from the card.
    Demander à FixBot
  12. HP Chromebook 14-Q010DX Motherboard Replacement: étape 12, image 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement: étape 12, image 2 de 2
    • Remove screw from card.
    Demander à FixBot
  13. HP Chromebook 14-Q010DX Motherboard Replacement: étape 13, image 1 de 1
    • Gently pull card at a 45° angle to remove it.
    Demander à FixBot
  14. HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: étape 14, image 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: étape 14, image 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: étape 14, image 3 de 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
    Demander à FixBot
  15. HP Chromebook 14-Q010DX Motherboard Replacement: étape 15, image 1 de 1
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
    Demander à FixBot
  16. HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: étape 16, image 1 de 2 HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: étape 16, image 2 de 2
    • Using your fingers or spudger, pull out the connector.
    Demander à FixBot
  17. HP Chromebook 14-Q010DX Motherboard Replacement: étape 17, image 1 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 17, image 2 de 3 HP Chromebook 14-Q010DX Motherboard Replacement: étape 17, image 3 de 3
    • Remove all of the indicated screws.
    • Pull up on black strip to remove the monitor cord.
    Demander à FixBot
  18. HP Chromebook 14-Q010DX Motherboard Replacement: étape 18, image 1 de 1
    • Gently remove motherboard.
    Demander à FixBot
2 autres ont terminé cette réparation.
Kevin Piper
Membre depuis le 01/16/15
1 602 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 17-2, Watkins Winter 2015 Membre de l'équipe USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 membres
8 tutoriels rédigés
4 commentaires de tutoriel
Can someone just explain for what the sensor board is needed?
martindoerflinger - Réponse Partager
Let's the motherboard know when the lid is closed.
Jeff Briedwell - Réponse Partager
Hi! How do you start a chrome book from motherboard? Since I am doing a project I need help with that question.... Please send a mail with the explanation on my mail: steffe010929@gmail.con
Stefan - Réponse Partager
hope some one is still maintaining this site, i would like to know if i would be able to use a motherboard from another HP chromebook in the same product line for example if i have a motherboard from the 14-q010dx can i swap it with the motherboard from the 14-q010nr? thevet82@gmail.com
david saldivias - Réponse Partager
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 22
Total : 5,118
