Introduction
This guide will require removal of 3x5mm screws (on motherboard) and 1x3mm screws (on sensor board).
Ce dont vous avez besoin
Flip the laptop with the base of the laptop is facing you.
Using the #00 screwdriver, unscrew these screws.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
Using a spudger, remove the white and black cables from the card.
Remove the 3 screws around the fan.
Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
2 autres ont terminé cette réparation.
4 commentaires
Can someone just explain for what the sensor board is needed?
Let's the motherboard know when the lid is closed.
hope some one is still maintaining this site, i would like to know if i would be able to use a motherboard from another HP chromebook in the same product line for example if i have a motherboard from the 14-q010dx can i swap it with the motherboard from the 14-q010nr? thevet82@gmail.com
