Aller au contenu principal
HP Chromebook 14-Q070NR Battery Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-Q070NR Battery Replacement, Keyboard: étape 1, image 1 de 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Battery Replacement: étape 2, image 1 de 3 HP Chromebook 14-Q070NR Battery Replacement: étape 2, image 2 de 3 HP Chromebook 14-Q070NR Battery Replacement: étape 2, image 3 de 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Battery Replacement: étape 3, image 1 de 3 HP Chromebook 14-Q070NR Battery Replacement: étape 3, image 2 de 3 HP Chromebook 14-Q070NR Battery Replacement: étape 3, image 3 de 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Battery Replacement: étape 4, image 1 de 3 HP Chromebook 14-Q070NR Battery Replacement: étape 4, image 2 de 3 HP Chromebook 14-Q070NR Battery Replacement: étape 4, image 3 de 3
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Battery Replacement, Battery: étape 5, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Battery Replacement: étape 6, image 1 de 2 HP Chromebook 14-Q070NR Battery Replacement: étape 6, image 2 de 2
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Battery Replacement: étape 7, image 1 de 1
    • Carefully lift the battery and remove it from the device.
Andres Martinez
Membre depuis le 10/02/17
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S9-G5, Remmell Fall 2017 Membre de l'équipe USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 9
Total : 394
