Aller au contenu principal
HP Chromebook 14-ak013dx WiFi Card Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-ak013dx  WiFi Card Replacement, WiFi Card: étape 1, image 1 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement, WiFi Card: étape 1, image 2 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement, WiFi Card: étape 1, image 3 de 3
    • Turn the Chromebook upside down, as shown in the first image.
    • Remove the five rubber feet pieces as shown using a spudger.
    • Proceed to remove all exposed 4.2 mm Phillips #1 screws on the bottom of the Chromebook.
  2. HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 2, image 1 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 2, image 2 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 2, image 3 de 3
    • Use a plastic opening tool to split the back panel from the keyboard.
    • Move the opening tool around the sides of the back panel to detach it. Do not fully remove the panel, taking note of the two ribbon cables.
  3. HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 3, image 1 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 3, image 2 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 3, image 3 de 3
    • Remove both ribbon cables attaching the separated keyboard to the motherboard.
    • The large black ribbon cable was a tab that should be pried open to loosen the ribbon from its hub. Use the plastic opening tool as shown.
    • Gently pull out the short white ribbon cable out of its hub.
  4. HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 4, image 1 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 4, image 2 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 4, image 3 de 3
    • Disconnect the battery cable shown in the first picture before moving on. This can be done with an opening tool if necessary.
  5. HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 5, image 1 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 5, image 2 de 3 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 5, image 3 de 3
    • Remove the piece of tape from the top of the Wi-Fi card.
    • Also, unhook the two cables from the card by lifting on the connectors.
    • Remove the single M2XL3 screw from the Wi-Fi card using a Phillips #1 screwdriver.
  6. HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 6, image 1 de 2 HP Chromebook 14-ak013dx  WiFi Card Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool to remove the card from the board. The card is now free to be taken out.
Nicholas Molargik
Membre depuis le 11/01/18
277 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G5, Harley Fall 2018 Membre de l'équipe IUPUI, Team S3-G5, Harley Fall 2018
IUPUI-HARLEY-F18S3G5
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 1,636
