Aller au contenu principal
HP Chromebook 14-ak013dx Internal Speaker Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: étape 1, image 1 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: étape 1, image 2 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disassembling the Body: étape 1, image 3 de 3
    • Starting with the laptop on its back, remove the 13 screws holding the keyboard in place with a P00 screwdriver (2 screws are hidden behind the rubber footers)
    • Open the screen, revealing the keyboard. Using a prying tool, 'pop' the keyboard out by sliding the tool around the edge
  2. HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: étape 2, image 1 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: étape 2, image 2 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Disconnect the Keyboard from the Body: étape 2, image 3 de 3
    • Gently raise the keyboard from the body, careful not to rip out the ribbons
    • With light pressure, flip the black bar holding the ribbons in place, and remove the ribbons from the body
  3. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Keyboard: étape 3, image 1 de 1
    • Completely remove the keyboard, place away from the body of the laptop
  4. HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: étape 4, image 1 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: étape 4, image 2 de 3 HP Chromebook 14-ak013dx Internal Speaker Replacement, Remove the Battery: étape 4, image 3 de 3
    • With a P00 Screwdriver, remove the 9 screws holding the battery in place
    • Gently pry the cable connecting the battery to the motherboard off
    • Battery will lift away from the body (screen will now be heavier than the body, be careful not to drop it)
  5. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: étape 5, image 1 de 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Left Speaker: étape 5, image 2 de 2
    • Gently disconnect the cable connecting the internal speaker to the motherboard
    • Using a P00 Screwdriver, remove the final screw from the left speaker
    • Using a prying tool, carefully remove the speaker out of the body
  6. HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: étape 6, image 1 de 2 HP Chromebook 14-ak013dx Internal Speaker Replacement, Removing the Right Speaker: étape 6, image 2 de 2
    • With a P00 Screwdriver, remove the final screw from the right speaker
    • Carefully remove the right internal speaker from the body
    • The entire speaker (barring some tape you may need to remove) should lift away from the body of the laptop
Cameron C Blanchard
Membre depuis le 09/16/20
524 Réputation
4 tutoriels rédigés
Équipe
dwsad Membre de l'équipe dwsad
Community
1 membre
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 83
