Aller au contenu principal
HP Chromebook 14-ak013dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: étape 1, image 1 de 3 HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: étape 1, image 2 de 3 HP Chromebook 14-ak013dx Keyboard Replacement, Opening the Case: étape 1, image 3 de 3
    • Using a p01 screwdriver bit, unscrew the 13 screws on the back of the laptop (two will be under the rubber footpads)
    • Flip to laptop over and raise the screen. You will need to use a tool to "pop" the keyboard off, slowly sliding the tool along the outside
  2. HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: étape 2, image 1 de 3 HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: étape 2, image 2 de 3 HP Chromebook 14-ak013dx Keyboard Replacement, Removing the keyboard from the Motherboard: étape 2, image 3 de 3
    • Carefully raise the keyboard off the body of the laptop
    • Locate two ribbons connecting the keyboard to the motherboard
    • Gently flip up the bars holding the ribbons in place, and remove the ribbon
  3. HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: étape 3, image 1 de 3 HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: étape 3, image 2 de 3 HP Chromebook 14-ak013dx Keyboard Replacement, Remove the Touchpad from the Keyboard: étape 3, image 3 de 3
    • Separate the keyboard from the body of the laptop
    • Using a p001 screwdriver, remove the two screws holding the touchpad in place
    • Gently lift the bar holding the ribbon in place, and remove the ribbon
  4. HP Chromebook 14-ak013dx Keyboard Replacement, Separate the Keyboard and Touchpad: étape 4, image 1 de 2 HP Chromebook 14-ak013dx Keyboard Replacement, Separate the Keyboard and Touchpad: étape 4, image 2 de 2
    • Carefully push on the 'knob' on the touchpad; the touchpad will fall out of the keyboard
    • Carefully store the touchpad separately from the keyboard if not immediately replacing the keyboard
To reassemble your device, follow these instructions in reverse order. Add the old touchpad to the new keyboard, and be careful reattaching all ribbons. Keyboard should 'snap' into place before put screws back on the body.
Cameron C Blanchard
Membre depuis le 09/16/20
524 Réputation
4 tutoriels rédigés
Équipe
dwsad Membre de l'équipe dwsad
Community
1 membre
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 102
